have got all bolts off as manual instructed but i cannot find the shift rod retaining screw to let shift rod come loose can anyone explain what and where this is i am trying to replace the waterpump/impeller model #j175txctd 1983 model
remove your starter and probably your starter solenoid to remove the starter. This way you can see under the bottom carb. Sometimes you might have to remove the bottom carb. It depends on what kind of motor skills you have with your hands. Good luck it is not hard to get to that bolt holding the shift rod.
