I just worked on a Johnson Super Sea Horse 35. I cannot find a model number but I did locate the serial#, which is 1992876 how do I find out what year this is. I would like to buy a manual. This is a motor My father bought. The motor runs pretty smooth but backfires once in awhile, I think it is sucking air in the fuel line. I am planning to replace them. I can't get the motor to pump water thru the output that is above the water. I pulled the thermostat out and flushed water thru the motor,I think. I started the motor with the thermostat cover off and the thermostat removed, primed the side where the thermostat sits.
The motor started pumping water I replaced the cover while the motor was running and I began to get some water coming out the output above the water. After re-starting the motor the water did not pump again until I took off the cover and primed it again. now the water does not pump even after priming it. The motor is in a 35 gallon trash can filled with water. the water is about 4 inches above the water pick up screens. The motor had set for a few years and probably has not been started for awhile, maybe 2-3 years. does anyone have any Ideas on the water problem. By the way I did pull the impeller and it is in suprisingly good condition still soft and no signs of dryrought.
any info appreciated!!
rockjul
rockjul
