Hi, I am new to this forum, seems to be many knowledgeable people here. I recently purchased boat with a 2000 90 HP Honda. It had sat up for a while, so the first time I fired it up it ran terribly. I sequentially removed the spark plugs and realized that #1 and #3 cylinders weren't firing at all. I removed the carbs and the #3 cylinder idle jet was clogged, after cleaning it started working properly, but I did my best to clean #1, and it didn't help. I have since soaked the carb in carb cleaned and that didn't help. I then swapped the #1 and #2 carbs to isolate to problem to the carb, and sure enough, after swapping, the #2 cylinder stopped firing. I am not sure what more to do to this carb other than soaking it more. Any ideas are appreciated.
