Re: can't find water pump repair kit for M35B
Just an FYI.
Model number M35B isn't listed in the part suppliers
catalogs, or at least the (3) other websites I searched.
This is a 1981 motor, and so I guess it was dropped from the
part listings being so old.
Anyway, I was able to find some of the common wear items
right here on iBoats.
They carry numerous other Tohatsu parts as well.
I listed some for the benefit of others.
edit: The Mallory Impeller will not work on this motor. The OEM impeller (IMP35ABM) is available at
https://www.internetoutboards.com
No water pump kit is available.
Sierra Carb kit 18-7290, $92.99 (Kit contains enough components to rebuild 2 carburetors)
Replaces OEM part #
MERCURY MARINE 84419M
NISSAN/TOHATSU 345-87122-0
YAMAHA 696-W0093-02-00
Mallory Gasket, Drain Plug 9-60103, $.99
Replaces Original Equipment Manufacturer(OEM):Nissan / Tohatsu
Replaces Original Equipment Manufacturer # (OEM #):332600060M
Fits Application:All Models
Mallory Drain Plug & Gasket 9-72656, $5.99
Replaces Original Equipment Manufacturer # (OEM #):332600051M + 332600060M
