Can't find this Bravo 1 bellhousing part?
tank1949
attached is photo showing Bravo 1 hinge pin with SS washer on it. The SS washer(s) fit inside the Bravo 1 bellhousing recessed cavity where hinge pin is bolted. 2 per bellhousing... There is a second fiber washer (reddish brown) or spacer to eliminate friction between bellhousing and ring. One on each side.... It is in photo under tape measurement tool. I looked for replacement but cannot get anything to return in my searches. I assume it would be called "hinge pin spacer" but I cannot find it. If anyone knows its technical name, please respond. THX!
wrench 3
Mercury just calls both of them "washer". The fiber one is part #41721. The metal one is 806241.
