Can't find replacement part any suggestions
rakess
I have a Force 9.9 hp motor from early to mid 90's. The lower gear housing and cage assembly are cracked. The part for the cage assembly is 817756A 2. This seems like a very common part on a lot of motors but it is listed as obsolete. So the question I have is what do i do? Do i take it to a machine shop and have them try and weld it? would Aluminum Epoxy hold it with the stress of the Gear assembly being there? Am a just out of luck? I can't see paying $660 for a $37 dollar part. Could I replace the housing and cage assembly with another model and reuse most of the parts? This is my first boat and I am just trying to figure out what options i have. Any suggestions would be greatly appreciated.
Below is a link to where i found most of my information and part numbers.
http://www.**********/parts/search/Merc/Force/1984/H0091H84D/GEAR HOUSING (ALL MODELS)/parts.html
jerryjerry05
Re: Can't find replacement part any suggestions
Serial # model# needed?
Depending on the cracked area if it can be welded???
Pictures?
The housing could be welded too??Pics.
This site won't allow other sites addresses or links.
You need to put in spaces between the words like, boats . net .com to post.
Alum.Epoxy won't last.The lower will heat up and cooldown and it will come loose.
rakess
Pictures?
Jerry Thank you for your response here is the requested info.
Link info:
http://www. boats .net /parts/search/Merc/Force/1984/H0091H84D/GEAR%20HOUSING%20%28ALL%20MODELS%29/parts.html
It is a bit hard to see but the cracks are around the screws. the bottom screw is not even holding on to anything except the wing of the part that has broken off.
