can't find any info at all
fornevets
I got this old 15 HP motor, and can't find any info on it. I mean there is nothing no model#, no serial#, nada. Please if anyone knows a trick or two to find it, it would be appreciated. Oh yeah, it is a johnson, im thinking from the 50's.
Ross72
Re: can't find any info at all
There should be a quarter sized silver plug on the motor that might have a number on it. Also, post some pics, I'm sure somebody will be able to help.
Lostfisher
What does the motor look like is the hood fiberglass or metal?
1946Zephyr
Well, if it is infact a Johnson and it's a 15hp from the 50's, then it could be none other than a 1956 model. The years prior to that (1953 - 1955) the 15 hp was under the Evinrude name only. In 1957, the 15hp was bumped up to 18hp.:cool:
1946Zephyr
Awesome link, F_R. Thanks for posting it. I always liked those ad brochures.:D
fornevets
Thanks everyone, I found the plate under it looks like house paint. The # is there, and it is an evinrude 53-54. Do you think an after factory paint job will decrease value alot. The cover is metal, almost thin like aluminum.
What would something like this go for in price nowadays. I have the old split tube connector for the gas connection on the side, and an old gas can as well.
soundchaser
You didn't hit the lotto, on best day $200.00 on worst day $100.00
If it wasn't repainted and it was beautiful, Well it isn't so.
1946Zephyr
These are excellent motors though and would be great to put to use. Ignition parts and impellers are readily available here. If you needed to go any further into it, the rest of the parts can be found with a little searching.:cool:
