Model # J30ELENR
It's about a 1993 model. I'm trying to change the impeller. I searched the forums but cannot find my problem. The threads in the forum talk about a shift linkage under the carburator. I cannot find one. I spoke to a local outboard mechanic by phone & he said there is not a linkage under the carb. But when the lower unit drops (as it does), there is about a 3/4 in. gap. He said in there I should see a brass coupling with 2 screws. I should undo the lower screw & it should drop right off. Well... there is no such thing visible. Can you tell me what to do next????
Thus far, I have taken off the 4 bolts to the lower unit as well as the upper one. I can force the lower unit down about 3/4 inches but no more.
Thanks
Mike
Thanks
Mike
