1977 SILVERLINE
- Jul 11, 2011
- 113
My 1977 silverline outdrive will not go in/down. I have filled the pump with oil and it still will not go down. This boat has three switches to control the trim. If I loosen a line on the trim cyls oil will come out and the drive will go down. Once its down I can use the controls on the boat and it will go up like it should, make a laboring noise when it has hit the end of its stroke. I then press the in button and you can hear the pump run but it will not go down. The pump just runs and runs but it will never pick up its prime. It does not labor like the return oil cannot return, it just runs fast as if there is no oil to prime itself. Ive been working on it for 2.5 hrs and still have gotten nowhere. The worst part is it used to work flawlesly last year and now it doesn't work at all?
Thanks for any advice
