Can You Tow
Jeff Walkowiak
Re: Can You Tow
you must clamp off the water hose going from the pump to the top of the engine or risk forcing water in to the engine crank case,, and you should place the lanyard inside the hull by the clamp so you remember to UN CLAMP it before using the ski or you will damage it that way
