Re: Can you swap auto parts into marine engine?
yes you can do that it wont hurt a thing, as long as its just little things,
Dude, c'mon, if you're not going to answer his question properly, than just don't answer it at all. What you just said there could be interpreted the wrong way and could be very very dangerous.
There are two MAIN reasons why marine parts are different:
#1 corrosion resistance - water pumps, head gaskets, frost plugs, etc
#2 Safety - Alternators, Starters, Distributors, Distributor Caps, etc
Any electrical part in a marine engine must be built in such a way that it does not allow a spark to mix with the air around it. In the case of a distributor cap, it must be sealed. Often Automotive caps have vents in them.
So to answer you're question, unless you can cross reference the exact part numbers, go buy the proper cap for you're marine engine. Putting an automotive cap in there could cause an explosion and kill people.
