jiminmontana
- Dec 22, 2009
- 77
The 1957 Lone Star Caribbean that I am restoring is rated for 150 HP. My motor is a 1964 Johnson Meteor 90 HP, and that seems a bit on the slow side for a 19 footer. I have access to 2 more of the same motors for $100 each. They need work, but the key parts are good and kits are available for the little stuff. I am going to buy one anyway for replacement gears if needed later.
This model boat was ideally fitted with 2 motors of 75 HP. The boat is rated for 150 HP. If I add balast and beef up the new stringers, gunwales, thick decking, and new transom with a steel plate, can I put 2 motors of 90 HP on the back?
Also, a kicker would be a final thought when I don't want to run that much power. Too much weight for all three? The 1964's weigh 227 pounds each and the kicker is 47. Anyway, I have decided to fix this boat up right. The only real change is to put in a 35 Gallon Moeller tank below deck. And that's only because the 55 G is too tall! Starting on the transom Saturday -- Lord willin'.
Pics are on my blog as listed below my signature. Thanks for the good advice and contacts lately. I am a CADET! and need the good replies.
