Can you pull tubes behind Jazz?
xjnmud
Ive tried searching for this: Can you pull a tube or skier behind and 94 bayliner jazz. If so where is the best place to pull from ie the dock cleat trailer tie down points or the things on the engine hatch hinges what is the capacity of them? Im looking at the demon tow harness that uses a pulley system to distribute the load between two points. anyother suggestions, has anyone experimented with this?
kend301
Re: Can you pull tubes behind Jazz?
Yes you can , I pull skiers and tubes , I have used both the transom tiedowns and the dock cleats to tow .. no problem at all .. Of course the Ideal thing would be to put a ski tower on the boat . The rope you are planning on is a very good Idea .
