can you get the tilt/trim switch on the throttle
bluecollerboater
Does anyone know if I can get a replacement switch for my throttle control? Or do I have to get a three way switch and mount it to the console? Thanks in advance
Phantom_II
Re: can you get the tilt/trim switch on the throttle
Kinda interested in this myself. Mine is intermittently sticky.
I figured on taking it apart but an OEM replacement would be easier.
Chris1956
These switches are normally a replacable item. Determine what brand the control is and ask the OEM.
12vMan
The mfr. of the boat may have used an aftermarket throttle assy. also. If this is the case the name of the mfr. should be on it and you can google the name to find a replacement switch.
Gary H NC
Post a picture of your control.Someone here can tell you what it is.
