Re: can you change a mercruiser carb engine to fuel injection
i know someone who took all the EFI stuff off a camaro IROC-Z 5.0 tuned port and put it on his boat. it's still working fine as of now. the automotive stuff is sealed up pretty well, not quite marine spec but still usable. his was closed cooling, make sure you use something with a cast iron intake if you are open cooling.
be smart, don't mount the engine computer next to your bilge pump, make sure your grounds are adequate, if you are resourceful and get everything at the junkyard you should be into it for about $200 in parts. worst case is you will have to swap the carb back on.
