Can someone identify th his part?
I broke this part and can't find it anywhere. I found one picture of the part on this forum. Mercruiser 350 v8
Thanks!
Fun Times
Hi there, welcome to iboats....Looks like you are in need of original Merc part number 806917T or the latest number 807097T item number 24, http://www.mercruiserparts.com/bam/subassembly/31871/1953/100
With that mentioned the part looks to be no longer available so you may have to start calling some Merc dealers to see if they have an old throttle body in the junk pile or ask them to run the part number to see if any other merc dealer has one listed in old stock.
Image search the part number for a visual....Hope this helps some, good luck.
alldodge
If your unable to find it, and your kind of handy you might be able to make one out of aluminum bar stock. Had a plastic part break on my throttle body (different then yours) and had it made at a machine shop
