goldman812
Thread starter- Joined
- Jun 12, 2009
- 4
i have a 5hp gamefisher motor. one day i was out trolling and the motor shut off. i tried to start it and could not. i got a tow in and when i got back to the dock it started. the next day i took a look at it and found nothing wrong. i changed the spark plug with a brand new plug,took the carb apart and it was spotless, checked float bowl height and all was good. put back together and ran it in a garbage can full of water and it ran fine. idled fine and ran all speeds no problem. i took it out and he water to go fishing and when i got about 40 yards from the dock i was on a plain it started to die and was at idle at full throttle then died. i pushed the primer bulb one time and it started and i went back to the dock. it did not run good all the way to the dock. at the dock i tied it up and started it and it ran fine. i put it in gear and gave it full throttle and it seemed ok. i took it out again and it did the same thing. sometimes it runs for 40 yards and others it will go 100 yards. i played with it at the dock while tied up and i could make it do it there. everytime i had to push the primer bulb to get it to start. so i figured it is a fuel issue. i replaced the fuel pump diaphram and filter and gaskets. i cleaned the carb again, replaced the fuel line and primer bulb. i checked all fuel lines and all are clear. i put it back in the garbage can and it ran fine, but did do it one time in the can. i ran it in the can for at least an hour. it ran in the can last time as well, but did not run at the lake. it is a 10 foot boat, very light. i am going to go and try again at the lake, but i suspect it will do the same thing.. anyone have anyu ideas????
so to recap.. new spark plug, new fuel pump,clean carb,new fuel line, new primer bulb,new fuel filter, clean fuel lines.
