Re: can parts be used to convert an aluminum boat
Yes it can. I did one this past winter and have two more to do this winter. The "static water line" is only a problem when you take off for the first time on any given day. All it takes is a few jabs of the throttle to fill up the pump cavity then after that it's good to go. It is not as easy as it sounds or looks to be, but if you have time and the shop space along with tools and if you have any mechanical ability you can do it. I would be glad to give you a few pointers if you are interested.
