can my SUV tow a 22' cabin cruiser?
jetsetmodern
Hello,<br />I need to move my 1979 Sea Ray 21.5' cabin cruiser from NW Arkansas to Chicago. The trailer seems to be in good condition. I am wondering: is this boat too big/heavy to be hauled by a 4WD 1997 Mercury Mountaineer SUV? The distance is about 618 miles.<br /><br />Can I tow it? If not recommended, can anyone recommend a reputable company to deliver it?<br /><br />thanks!<br />Joe
Silvertip
Re: can my SUV tow a 22' cabin cruiser?
A quick check of a 21 footer on the Sea Ray site showed weights of 4700 & up for a 21 footer. It and the trailer are going to be in the 6000 - 6500# range which I'm guessing is at least 1000# over the towing limit for your vehicle. If you have the V6 engine it would not be an enjoyable trip, nor a very safe one.
Formula1974
Our Blazer has a rating of 6000 pounds. I would try it if it was me but its not. :)
Northern Eclipse
Being a Cabin crusier I would be more concerned about wind and passing trucks, I would suspect the boat is a little bit heavier than the 6000lb tow rating provided you have a Tow package. I tow 4800lbs load with 98 Explorer, Granted I'm satisfied and comfortable with it, but I would not tow much more with that truck. Get your sea ray weighed. and decide from there. One other point Mountaineer/ Explorers should not tow any trailer Longer than 26 or 27 feet so if your towed length is hitting close to that and your about max or over tow limit I would not chance a 618 mile trip.
roscoe
Northern Eclipse, enlighten me with a little more info on the trailer length limit you mention above. Why can't an explorer tow a longer trailer?
Northern Eclipse
It comes down to what is safe, these trucks are narrow and have a short wheelbase, If your towing a long trailer and it sways, it could whip the truck around badly causing a total lose of control. I just checked my manual again for my 98 Explorer it states trailer length is not to exceed 27ft, my trailer is 25 ft I had it take off swaying due to some very sudden high wind gust a few years back that caught me off guard running downhill at about 55mph, just about pulled the truck into the ditch. I'v never experinced such a violent sway and I'v been towing campers and boats ever since I was able to drive. I think with your boats height and length there would be alot of surface for wind to push it around, there are more than just weight limits to consider, the longer to trailer the farther it will travel side to side if it was to sway for any reason, think of a trailer as if it was a pendulum the longer the trailer the more force it will apply to the back of the truck and the more momentum it will generate. I'm not sure if Mountaineer has that info in the Manual, since those Mercurys were not available in Canada, but I could not see why it would be different since the Explorer and Mountaineer are basically the same truck. After all said and done I'm comfortable towing with my Explorer, but then again I understand this trucks limitations and really feel if I was to tow anything larger then a larger truck would be in need, since I'm already close to its max, The limits stated for these trucks are as good as it gets for a midsize truck but thats it for them anymore and it could be dangerous.
craze1cars
You're really stretching the limits of that truck. However, for just a one shot deal, and with an understanding that you need to be careful and might do some transmission damage to your Mountaineer, I might consider it on the following conditions:<br /><br />#1, you are experienced at towing large trailers. If you haven't any experience, don't even try. But if you have towed before then: Keep speed below 55 mph all the way, keep it out of overdrive, change all fluids in your truck before the run, have your truck's brakes checked for any problems, make sure you have a full 2 inch receiver hitch, with a load leveling hitch setup, make darn sure you have good functioning trailer brakes AND the necessary electronic controllers on your truck to run them properly, you are willing to flaunt with the law (if you're over GVWR, you are illegal).<br /><br />As a side note, on a boat/trailer that old, your comment of "Trailer seems to be in good condition" is an eyebrow raiser for me. You need to go through the entire trailer before such a long run. Inspect/repack all wheel bearings, check tires carefully for any signs of rot, make sure you have a good spare, lights work properly, and make sure trailer brakes are functioning properly....without trailer brakes your Explorer will NOT be able to stop this thing within a reasonable distance.<br /><br />Another alternative: Rental truck. A full sized Uhaul or Ryder would do the job, and maybe even regular car rental places could get you a Suburban, or full size pickup, or 9 passenger van, that's equipped to pull. Or pay someone to deliver it...sorry I don't have any suggestions of who. Good luck!
