can my prop cause this
shawn 74
I have a 1980 16ft fiberglass boat with a omc 3.0 140 hp i/o in it at full throttle it only revs to 3200 - 3300 rpms there is alot of wake being kicked up behind it and i can't get it to plane out the prop is a 15 x 17 the engine runs great other than low speed and rpms. if you think it could be the problem what prop do you recomend.
Re: can my prop cause this
Ayuh,... It sounds like it's Down on Power, or geared too high...
Try a smaller pitched prop to get the rpms up to atleast 4000, at wot...
