Originally posted by XcellR8:<br />
Originally posted by Stillfishing:<br /> Guess you answered my question!<br /><br />Your favorite prop so far seems to be the 13x19 alu. With your other symptoms, you're wise to think of motor height next. Check the position of the AV plate relative to your keel - most boats need it to be level with or slightly above keel level at stern.<br /><br />As there's plenty of scope to raise the motor, and as some of the symptoms you've described are often cured by doing it, then why not use a plate as SoLittle suggests, and go ahead and experiment.<br /><br />Watch for prop ventilation and motor water pressure issues as you do it. Keep a record of speed and WOT with each change.<br /><br />The torque-steer you mentioned could have something to do with a low motor, but check the position of the trimfin below the AV plate. Maybe by adjusting this you can minimise torque-steer (swing the trailing edge right to counteract a starboard-steering boat, and vise versa).<br /><br />Post back results huh?
Thanks, right now the A/V plate is level with the keel. For some reason there was no trimfin on the boat when I bought the boat but I put one on. I've tried adjusting it a couple of times but it sounds like the wrong way (I turned the trailing edge to the left thinking it would make it go that way). I also cut a notch out of it (as a dealer told me to do) as there was only about 1/8" of clearance with the 13.75 x 21p Trophy Plus prop installed. Maybe this has something to do with it?<br />
Trim Fin and A/V plate level with keel <br /><br />When you say watch for water pressure do you mean make sure the stream coming out the back doesn't weaken or become intermittant (I don't have a water pressure gauge)?<br /><br />I like the idea of shimming the motor plate with an aluminum plate so it can be put back how it was if it doesn't improve the situation. I should probably mention that all my testing has been with only two people in the boat. I was thinking that before I try rasiing the motor I should load the boat up with 4-6 people to see how it reacts (I still have the 13 x19p aluminum prop to use for now).
