Glastron3.0GLP-C
- Oct 21, 2012
- 61
Can I use this riser or do I need a new one? What can you tell from the photos? Note one small area that looks thin. Is this normal? The engine is a Volvo Penta 3.0l GLP-C.
I took the riser out because of a blown hose between the thermostat housing and the engine circulation pump. So I suspected a restriction in the system. I found an impeller piece at the very end of the riser under the exchaust rubber hose.
