can I use these powerheads to replace mine?Merc 650
Mainiac
I have a Mercury 650 serial#:4140468 i need a new head...the top of the middle cylinder is blown off mine:eek:.....i have found 2 powerheads serials:3150137 & 2506526 I don't think these will work with the motor i currently have but wanted to see if anyone with more knowledge than me on the issue would know for sure.
Faztbullet
Re: can I use these powerheads to replace mine?
From the serial posted you a have a 3 cylinder 65 as the others are 4 cyinder 65.
Mainiac
Yea I guess I should have checked the obvious first! None out there has a 3cyl merc 650 head just laying around they want to get rid of do they?
Faztbullet
Re: can I use these powerheads to replace mine?Merc 650
You want a bolt on and go or one you can freshen up? :D:D
Mainiac
everything on my merc 650 is good with exception of the engine block.... would be nice to find a cheap block so i can replace my broken one and have a working outboard. if I were to buy antoher working outboard I would probably go a bit bigger
Faztbullet
Pm me as I have a complete 650 motor that I am parting out....
