Can i use my left over premix 50:1 in my 2 stroke snow blower?
ob
Re: Can i use my left over premix 50:1 in my 2 stroke snow blower?
Only if it calls for a 50:1 mix and is watercooled.
I do it all the time..........<br />Outboards..<br />Chainsaw..<br />Weedwacker..<br />Leafblower..<br />Iceauger..<br />Same mixed, Stabilized gas in All of them.......<br /><br />I fail to understand the "Watercooled" comment, ob.......
llfish
The fuel/oil ratio for most lawn equipment is 24:1 or 32:1. That is why you do not want to use it your lawn equipment.<br /><br />I mix my left over boat fuel with the fuel I use in my truck. One gal. of 50:1 in a tank of fuel. This may not be the right thing to do but have never ran into a problem that I am aware of.
BillP
Air cooled 2 stroke oil and water cooled 2s oils are blended differently so crossing over for long term use isn't technically correct. Some do this all the time without problems but it isn't the best way to go. Using a tank every now and then shouldn't be a problem though. I've done it in lawn equipment when in pinch and had no problems. Just make sure the oil ratio is ok.
crazy charlie
Thats all I have ever done.Charlie
phatmanmike
i use it to burn the bodies
walleyehed
I'm startin' to worry about you, Mike... :D
djvan
We dump our leftover boat gas into our vehicles, in the fall. No problems yet, been doing it for years.<br /><br />DougV>
Solittle
I would be a bit leary of putting it into todays automobiles due to all the sensors and computer technology.
Lou C
I recall reading that the oil is supposed to be different for air cooled vs water cooled 2 strokes, but I don't know if it is different enough to matter. My Toro single stage blower with the Suzuki 5 hp takes 50:1 but I only use the oil for air cooled 2 strokes.
gewf631
Even if you have, say 5 gals pre-mix left over, you're only talking 12 oz of oil - put that into a reasonably full automotive tank and there ain't enough to worry about.
Terry H
I use any extra premix in my truck, but at about 200:1. 5gals of premix with about 15 gals gas. I did have a problem a couple years ago but some "Deep Creep" fixed it. :)
swist
Yeah, the "W" in tcw-3 means "water cooled". Presumably water cooled engines run at a lower (and more consistent) temperature, and maybe there's some long term difference if you use it in an air-cooled engine but I've shared my 50:1 tender gas can with my (50:1) chainsaws for 35 years now and have never had a problem. Obviously the mix ratio have to be the same. <br /><br />I am no expert but logic would say that the amount of heat that will kill an engine just can't be all that different among various designs. Do air-cooled engines really run so much hotter that special oil is really needed?
BillP
Here's a cut and paste from a well respected oil mfg who has oils for air and watercooled. It's about aircooled snowmobiles but shares info on air cooled 2 stroke oil VS water cooled 2 stroke oil. Also note about oils and catalytic converter failure. <br /><br />Most of the OEM manufacturers oils are produced by specialty lubricant manufacturers, not the OEM and these formulas are tested and approved by the manufacturer for use in their sleds. The oils are blended according to a formula that has been developed for two-stroke snowmobile engines and this oil is usually given a rating from the American Petroleum Institute (API) of "TC", the Boating Industry Association (BIA) rating of "TC-W", or the National Marine Manufacturers Association (NMMA) rating of "TC-W II." All of these formulas were originally developed for outboard engines and were modified to suit the needs of snowmobile engines; however, motorcyclists that used these oils found that their air cooled engines ran the best on the oldest API TC oils. These API TC formulas contained a higher level of bright stock 150, a high density petroleum base stock with a consistency similar to honey, that gave the best protection against piston seizure and bearing failure. To prevent carbon buildup in the piston ring grooves, these TC oils used metal based detergents that were very effective in motorcycle engines but caused some problems in outboard engines when operated at long periods of time at one throttle setting. A whisker-like bridge could form across the sparkplug gap to permanently foul a cylinder under these conditions while the motorcyclist operating his engine at a constantly changing throttle setting never encountered this problem. When the BIA developed the TC-W rating, they excluded the use of these metal-based detergents in favor of organic detergents to eliminate this problem in outboard engines. These TC-W oils (two-cycle, water cooled) also contained lighter base oils without the bright stock 150. For engines operating in the 4,000 rpm to 5,000 rpm range, the absence of the bright stock 150 had no affect on piston and bearing life. However, off-road motorcyclists testing these new TC-W oils were disappointed with the bearing life of their engines operating at 10,000 - 11,000 rpm and quickly returned to using the TC oils.<br /><br />The need for a clean two-stroke outboard oil was recognized when piston ring groove carbonization was seen as a primary cause for engine failure and a new formula designated TC-W II was developed. While this oil was significantly better for outboard use and was phosphate free, it still was not the optimum two-stroke oil for engines operating above 8,000 rpm. The phosphate free mandate was from a concern raised by environmentalists that realized that outboard engine use could permanently pollute fresh waterways just as the soap industry was beginning to eliminate phosphates from their products for the same reasons. But, snowmobiles, motorcycles and quads do not emit their exhaust directly into the water, as outboards do. Recently, efforts to develop an even cleaner outboard oil have produced the latest NMMA TC-W3 and this oil, although containing no bright stock 150, has produced better levels of lubricity and cleanliness in piston ring groove areas, however, still not nearly as good as a purely 'snowmobile use' developed oil.<br /><br />The BIA evolved into the National Marine Manufacturers Association (NMMA) which works closely with the outboard manufacturers. the NMMA mandated that all oils would contain non-metallic detergent additives, no phosphorus or phosphates, if they were to have the approval of the NMMA and the outboard engine manufacturers agreed to recommend only the NMMA approved oils.<br /><br />Also, many marine dealers were concerned about the flammability and flash point of out board oils. Since larger engines were now consuming huge amounts of oil they had to stock several hundred cases of oil per season. This amount of oil stored in one location had alerted the fire marshals and insurance companies attention and a solution to this risk was addressed by the NMMA. Higher flash point oil with a flash point over 200 deg. F was what they needed to achieve a category 3B fluid rating, just enough to avoid the hazardous storage and shipping restrictions they were facing with all other two cycle oils. Oil manufacturers were forced to use TC-W3 additives or blends with high flash solvents if they were allowed to keep the NMMA license. The high flash solvents caused all sorts of unburned oil problems in engines, but the insurance carriers were happy.The combination of non-metallic detergents and high flash solvents in the new TC-W 3 oils later caused some severe ring sticking in many engines and Yamaha actually required owners to use a 'ring-free' fuel additive to maintain their warranty, a symptom of being forced by the NMMA to recommend the new oils!<br /><br />This is almost exactly the same situation that developed with the American Petroleum Institute (API) and the Automobile Manufacturers. They were dealing with legislation that mandated exhaust emission systems to last a certain mileage under warranty and catalytic converter failure was known to be linked to the zinc-phosphorus content in motor oils. The API, in response to the auto makers, soon mandated restricted levels of these additives and is slowly lowering them. The problem was that motorcyclists depended on these zinc-phosphorus additives to protect their higher reving motors from damage and they were a victim of a legislation that did not even apply to them (very few motorcycles have a catalytic converter). Now snowmobilers are victims of this exact same legislative situation, the elimination of phosphorus from two-cycle oils. But they do not need to be! Why? Because motorcyclists and snowmobilers can buy motorcycle oils and snowmobile oils and bypass the restrictions placed on automobiles and outboard boats.<br /><br /> Sea-Doo and Ski-Doo didn't go with the NMMA, they refused to allow their engines to be destroyed and recommended to their owners NOT TO EVER USE TC-W3 oils! Polaris bought the TC-W3 sales pitch at first, recognizing an inventory advantage to having only one two cycle oil to be used in their watercraft, quads and snowmobiles. But they soon discovered the same problems many had already found with the TC-W3 oils when used in a sled. Ring sticking, exhaust port blocking and low temperature flow problems. Suddenly all those advantages of the TC-W3 oils they read about from the additive maker's brochures weren't working out when weighed against all the engine failures! Have you noticed they have gone back to purely snowmobile developed snowmobile oils? Currently there are not any snowmobile OEM's recommending the outboard NMMA TC-W3 oil, and there is a reason for this. They are not acceptable in today's powervalve equipped snowmobiles! Only oil companies with little actual knowledge of snowmobiles and their specific needs continue to try to sell snowmobilers an outboard oil for their snowmobile...and this is because they have a vested interest in doing so...economy of scale by combining several markets into one and selling just one oil.
D
DJ
Guest
Just because people have done it for years doesn't mean that your equipment isn't going to self destruct. Nobody on this board is going to pay your repair bill when it melts down.<br /><br />There is a DIFFERENCE between air cooled and water cooled two cycle oils, primarily ash <br />content.<br /><br />This pretty much sums it up, from the article above. <br /><br />
Air cooled units need the ash. TCW (two cycle water cooled) is low in ash.
ED21
Master Chief Petty Officer
Also modern 2 stroke equipment runs lean for EPA reasons & that makes them run hot. I wouldn't take a chance.<br />Well maybe snow blowers run cooler than chainsaws or weedwackers in the summer.
JB
I have a burned up Poulan chainsaw that says DO NOT use TC-W3 oil in air cooled 2 strokes, and DO NOT use less oil that the manual calls for.<br /><br />What would air cooled oil cost compared to a new sno-blower?
