Re: Can I use Humminbird XNT 9 20 T transducer with Humminbird 200DX?
Yesterday I hit something and my original XT 6 20 Humminbird transducer felt off. They are still available, but I'm thinking about newer model - XNT 9 20 T. Seem like it is much stronger design. It uses the same frequencies - 200/83kHz, and 20/60 degrees angles (XT 6 20 is 20/53). Are they compatible?
Humminbird Fishfinder Accessories
LOOK HERE>>>>>>>>
http://www.wmjmarine.com/marine-electronics-fish-finder-humminbird-fishfinder-accessories.html
Part No. Name Description
XTM WS Trolling Motor Transducer Trolling motor mount transducer, wide side 3 element, 15 ft cable. Allows the unit to look left, right, or down. Used with the WIDE EYE, WIDE VIEW, WIDE VISION, WIDE OPTIC, WIDE PORTRAIT, WIDE PANORAMA, WIDE PARAMOUNT, 300TX, 400TX.
XTM 9 24 Trolling Motor Transducer Trolling Motor Transducer, MicroDynamic, single beam, 24 degree cone angle, 200 kHz. Includes 15' cable, trolling motor mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XTM 9 24 T Trolling Motor Transducer Trolling Motor Transducer with Temperature Sensor, MicroDynamic, single beam, 24 degree cone angle, 200 kHz. Includes 15' cable, trolling motor mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XTM 9 20 T Trolling Motor Transducer Trolling Motor Transducer with Temperature Sensor, Hydrodynamic, dual beam, 24 and 53 degree cone angles, 200/83 kHz. Includes 15' cable, trolling motor mounting hardware. Used with Piranha 5, Legend ID40, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
XTM 9 CB 24 Trolling Motor Transducer Trolling Motor Transducer, coaxial dual beam, 15' cable. Used with Legend 3000, LPG2000.
DAP Angled Puck Transducer Angled-puck transducer. Dual element with 200 and 455 kHz. Inside hull mount with 20 ft of cable and a two part epoxy kit. Used with WIDE EYE, WIDE VIEW, WIDE VISION.
XAP 9 20 Angled Puck Transducer Single/Dual Puck Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Piranha 5, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
XAP 9 24 Angled Puck Transducer Single/Dual Angled Puck Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
STH 7 Bronze Thru-Hull Transducer Bronze thru-hull transducer, 30 ft cable with cam-lock connectors, 455 kHz. Used with the DIM 3-120.
STH 8 Bronze Thru-Hull Transducer Bronze thru-hull transducer, 30 ft cable with cam-lock connector, 455 kHz. Used with the DIM 3-600.
STH 7W Bronze Thru-Hull Transducer Bronze thru-hull transducer, 30 ft cable, 455 kHz. Used with the WIDE 3D VISION, WIDE 3D VISTA, WIDE 3D PARAMOUNT.
DTH W Bronze Thru-Hull Transducer Bronze Thru-Hull Transducer. Dual element with 200 and 455 kHz, 30 ft. cable. Used with WIDE EYE, WIDE VIEW, WIDE VISION, TRACKER EYE, TRACKER VIEW.
XTH 9 20 Bronze Thru-Hull Transducer Single/Dual Bronze Thru-Hull Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Piranha 5, Matrix 10, Matrix 15, Matrix 20, Matrix 25, Matrix 55, Matrix 65.
XTH 9 CB 24 P Plastic Thru-Hull Transducer Plastic Thru-Hull Transducer, tri-beam, 30' cable. Requires a hole to be drilled in the hull and the shaping of a fairing block. Recommended for hulls such as aluminum that cannot accommodate a bronze thru-hull. Not recommended for boats that are trailered or for wooden boats or for use with a wooden fairing block. Used with Legend 3000, LPG2000.
XTH 9 20 P Plastic Thru-Hull Transducer Single/Dual Plastic Thru-Hull Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Piranha 5, Matrix 10, Matrix 15, Matrix 20, Matrix 25, Matrix 55, Matrix 65.
DPT W Portable Transducer Portable transducer. Dual element with 200 and 455 kHz. Standard 15 ft of cable and stainless steel hardware with suction cup included. Used with the WIDE EYE, WIDE VIEW, WIDE VISION, TRACKER EYE, TRACKER VIEW.
XPT WS Portable Transducer Portable transducer, wide side 3 element, 15 ft cable. Allows the unit to look left, right, or down. Used with the WIDE EYE, WIDE VIEW, WIDE VISION, WIDE OPTIC, WIDE PORTRAIT, WIDE PANORAMA, WIDE PARAMOUNT, 300TX, 400TX.
XPT 9 24 Portable Transducer Portable Transducer, MicroDynamic, single beam, 24 degree cone angle, 200 kHz. Includes 15' cable, portable mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XPT 9 24 T Portable Transducer Portable Transducer with Temperature Sensor, MicroDynamic, single beam, 24 degree cone angle, 200 kHz. Includes 15' cable, portable mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XPT 9 20 T Portable Transducer Portable Transducer with Temperature Sensor, Hydrodynamic, dual beam, 24 and 53 degree cone angles, 200/83 kHz. Includes 15' cable, portable mounting hardware. Used with Piranha 5, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
DP W Puck Transducer Puck transducer, dual element, 200/455 kHz. Inside hull mount with 20 ft of cable and a two part epoxy kit. Used with the WIDE EYE, WIDE VIEW, WIDE VISION, TRACKER EYE, TRACKER VIEW.
XP 9 CB 24 Puck Transducer Puck Transducer, coaxial dual beam, inside hull mount, 20 ft. cable. Used with Legend 3000, LPG2000.
XP 9 20 Puck Transducer Single/Dual Puck Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Piranha 5, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
XP 9 24 Puck Transducer Single/Dual Beam Puck Transducer. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XP 9 20 T Puck Transducer Puck Transducer with Temperature Sensor. Used with Legend ID40.
SHS 7W Transom Mount Transducer Transom mount transducer, 20 ft cable, 6 elements, 455 kHz, 7 pin connector. Used with WIDE 3D VISION, WIDE 3D VISTA, WIDE 3D PARAMOUNT.
DHS W Transom Mount Transducer Transom mount transducer, 20 ft cable, stainless steel mounting hardware, dual element, 200/455 KHz. Used with WIDE EYE, WIDE VIEW, WIDE VISION, TRACKER EYE, TRACKER VIEW.
XT WS Transom Mount Transducer Transom mount transducer, wide side 3 element, 20 ft. cable. Allows the unit to look left, right, or down. Not recommended for high-speed use. Used with WIDE EYE, WIDE VIEW, WIDE VISION, WIDE OPTIC, WIDE PORTRAIT, WIDE PANORAMA, WIDE PARAMOUNT, 300TX, 400TX.
XHS 9 24 T Transom Mount Transducer Transom Mount Transducer with Temperature Sensor, MicroDynamic, single beam, 24 degree cone angle, 200 kHz. Includes 20' cable, transom mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XT 9 20 T Transom Mount Transducer Transom Mount Transducer with Temperature Sensor, Hydrodynamic, dual beam, 24 and 53 degree cone angles, 200/83 kHz. Includes 20' cable, transom mounting hardware. Used with Piranha 5.
XHS 9 24 Transom Mount Transducer Transom Mount Transducer, MicroDynamic, high speed, single beam, 24 degree cone angle, 200 kHz. Includes 20' cable, transom mounting hardware. Used with Piranha 1, Piranha 2, Piranha 3, Piranha 4, Matrix 10, Matrix 20.
XT 9 CB 24 Transom Mount Transducer Transom Mount Transducer, coaxial dual beam, 20' cable. Used with Legend 3000, LPG2000.
XHS 9 20 Transom Mount Transducer Transom Mount Dual Beam Transducer. Used with Legend ID40, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
XHS 9 20 T Transom Mount Transducer Transom Mount Dual Beam Transducer with Temperature Sensor. Used with Legend ID40, Matrix 15, Matrix 25, Matrix 55, Matrix 65.
