Can i swap harnesses chrysler 85 to force 85
Drymite
Can i swap the harness that uses ignition coils that came with my orginal force 85 that has a bad block now .on a chrysler 85 hp that uses a distributor?
alldodge
If your asking can you change the harness from one to another it is yes with a caveat, so long as the ignition system goes with the harness.
If donor motor harness is points ignition, then points goes with harness
If donor motor harness is electronic ignition then Elect Ign goes with harness
