can i rebuild 125hp force from 85hp force?
kostika
can i use the pistons from the 85hp to put into the 125hp? are they the same size piston?
Nugglet
Re: can i rebuild 125hp force from 85hp force?
they have different part numbers,,, so i'm guessing no
ex: 1989 85 p/n 700-834795
1989 125 p/n 700-834794T3 (both std size)
and from the looks of it,,, the only 125 pistons available are .030 over
i could be wrong though
kostika
thanks i will check it out tomorrow with the dealer
Frank Acampora
Depends upon the 85. If it is 1984-1989, it has the same bore as the 125 so the pistons will interchange--assuming the 125 and 85 have never been overbored and assuming the cylinders do not need reboring.
jerryjerry05
Yea they swap.Yea standard parts are still available.so are .010 and.020 over pistons.J
