can i put a larger hp powerhead on it?
cougar1985
i have a 1982 90hp v-4 evinrude. could you say put on the same year 115 powerhead on the motor?what are the differences between the 2?carbs, timing ?
emdsapmgr
Re: can i put a larger hp powerhead on it?
The 115 will fit. The 115 has larger carbs and the intake filler blocks. Not sure if it has the higher port timing or not. The 140 is where the major differences are: carbs, heads and exhaust cover/tuner, port timing.
cougar1985
according to the seloc manual they are all 99.6 cid. all are type 3 carbs all are the same timing. i quess what im asking is if i was to get a larger hp rebuilt powerhead would it fit ?maybe i could get a complete 140 with a pooched lower unit or something and do the old switcheroo.?? maybe im just dreaming lol.
Dhadley
All the late model V4 crossflows will fit. Your 90 has smaller ports and lower port timing. Until you change that there isn't a lot you can do to change hp. However, all late model V4 crossflows have the same bore & stroke, ignition, gear ratio etc. No matter what you do you aren't going to change the torque a heck of a lot.
Work on maxing out your set up. Once you get to the point you cant get any more fuel/air mix in or out then look at porting.
cougar1985
ok thanks. i guess what your saying is if i want say 140 hp go to a newer design motor? looper or say e-tec.
Dhadley
Either of those design put out a lot more torque, that's for sure! If you were going to take your motor apart anyway, it'd be easy enough to open up the ports and add the bubbled exhaust. If the motor runs good like it is we might concentrate on set up to make it as efficient as possible. You might be surprised.
cougar1985
what was thinking was that the boat is rated for 135hp and i have 90 so if i went to say 140 the boat would be that much quicker etc.and if the 140 powerhead would fit on the 90 motor id be that much ahead from say buying a 140 that may or may not be ok.
