Hello everyone,
I just recently put new fuel line in, replaced the fuel filter in my Carter, mechanical fuel pump (filter on the bottom), and installed the Mercury "anti-vapor" gas line from the fuel pump to the carb on my 1986 Mercruiser 470. My question is, when I go to start this thing for the first time, will the mechanical pump be able to pump gas from the tank when the entire line from tank to carb is dry? Or do I have to just shoot the carb with some spray start a few times to get the fuel pump to purge the line? If not, how should I introduce fuel into the line before buttoning everything up?
In advance, thanks for any help guys. Much appreciated.
