dst87mcssac
- Aug 20, 2007
- 91
Hello,
The Flywheel on my 1997, 75 HP, 3 Cylinder, One carb Force Motor has two bad places. I understand that there are magnets under the flywheel and there is a key way. I also understand there is a special removal tool that protects the crankshaft and there is a second tool to hold the flywheel during removal.
My concern is when I put the replacement flywheel on the motor, will I screw up the timing? Does the key way prevent it from going on in the wrong timing position? I have seen some used ones on E-Bay, but is there a place that has new replacement flywheels?
I need to replace my flywheel before it gets any worse.
Thanks,
Donald
Thanks,
Donald
