Re: Can I install on board battery charger
You didn't say whether or not your boat is docked or if you trailer it? If it's the later, then go online and look up a Stay N' Charge charging system. This charges your batteries while you are towing to & from your fishing destinations. There is no better way of charging batteries in a boat that is being towed. I've been using it for 5 full seasons now, charging a series 27 deep cycle and a marine starting battery. No problems, no worries.
If it's docked, then you have several other issues to consider. An on-board charger doesn't seem like a logical choice for your application. It will be expensive, add a lot of weight and generate heat in your boat when being charged. And you'll need house current hooked up to it. I think in this instance, you'd be best served by just buying a regular battery charger and bringing that to your boat via a long extension cord. But I don't know the layout of your docking?
