Instead of draining the cooling water and then adding antifreeze, I thought I read somewhere about doing this.<br />Take a 5 gallon bucket, connect a hose to it and connect the other end of the hose to the muffs. Fill up the bucket w/antifreeze mixture, then run the engine till antifreeze exits from the outlet.<br /><br />Can this be done?<br /><br />Seems like this would be simpler (once the bucket/hose contraption is rigged up).<br /><br />94 Wellcraft eclipse<br />4.3LX Mecruiser w/Alpha 1 Sterndrive
