I completely changed the reeds to Boyesen. The reed cage is still the stock cage.
I warmed the engine on the muffs. It ran fine. I did the compression test. I wasn't sure how the heck i could tell when it was cranked over 5 times. I can't see it spin or anything, it's too fast.
I cranked it over and counted to 5. About 110 PSI both cylinders.
Took boat out, ran ok at first. Didn't want ti idel at first, which is really not a new problem. We went out about 10 minuntes, to a post, stopped the motor and sat there fishing for about an hour,
Motor would not stay running after that. It would start, then die immediately before I could get it in gear. Messed with it doing this for a while, with no success. Changed the spark plugs. Tried a few more times, and got it going in gear.
Cruised around running throughout the throttle band for an hour or so. Every time we stopped after that, same thing, engine would cut off, then not run until I was able to get it into gear and the RPM would pick up before bogging down and dyeing.
I have another thread in Tohatus forums about this motor. I'll post this in there.....I was in a hurry to find out about the compression test with no reeds in, so I posted in here for a faster response.
http://forums.iboats.com/forum/engi...s/10236873-tohatsu-m70a2-stalling-won-t-start
