JoshGuitar
- Sep 21, 2010
- 12
I have a '79 Johnson 70 HP, currently hooked up to a one-lever remote. I also have a '77 Johnson 9.9 HP, currently set up with just tiller control. I'd like to set it up so I can control both from the drivers seat. They wouldn't be run at the same time, but I'd like to use the same controls for both if possible.
The 9.9 was added to the boat before I got it, and it already has the remote steering bracket with the relocated kill switch, and the cable clamps for throttle and shift, but nothing else.
Steering isn't an issue, I already have the rod to couple the engines together, it's just not hooked up.
I've seen the electronic remote kicker throttle setups, but I'd rather just control it from the same lever as the main engine. Is there something available already that will couple the controls on both engines together, or am I going to have to home brew something? I've searched around and so far haven't seen anything.
If I have to go DIY, the 2 options I see are:
1) leave the cables in place on the big engine. Run 2 cables from the big engine to the kicker, 1 for shift, 1 for throttle, so when the throttle lever on the big engine moves, it pushes the cable for the throttle on the kicker, same with the shifter.
2) Disconnect the cables from the 70HP, and make my own linkage that mounts somewhere convenient. Hook the cables up to my homemade linkage (basically just 2 levers mounted on a plate, with holes at appropriate points for cable attachment). Run 4 cables from my linkage, 2 shift, 2 throttle. Connect these to the engines.
Advantages of #1, it's simpler, and if I screw something up with the kicker controls, at least the 70HP control will be unaffected.
Advantages of #2, it's easier to individually adjust the linkages for both engines - with #1, if say the 70HP shift lever had to move 1/2" at its mount point to go from neutral to reverse, and the 9.9 had to move 1/4", I could just change the mount points for each cable on the linkage to get the proper travel.
Or is it easier to just run a second set of cables in parallel from the control lever?
I can't be the first person who's ever tried to do this, so maybe I'm using the wrong search terms, but any help would be greatly appreciated
