Hi I reasonly disconected the VRO on this 1985 70hp VRO. I have a bolt in the oil line and have sealed it on the end and folded the hose with a wire tie! I am having fuel delivery questions and was thinking I could swap the oiler/fuel pump for a standard fuel pump. I could just rebuild this one I think, but is there a way to eliminate this set up and put in a standard fuel pump? I have a standard pump on hand. Is there a place to connect it? I guessing the one thats there now runs on crank case pressure as well?<br />thanks steve
