(225 horse) Does anyone know if the gears in the lower unit are straight cut bevel gears, that can be run continuously in either direction, or are they like automotive rearend gears which "CAN" be run in reverse, but are helical cut, and designed to have optimal strength in the forward direction. Since reverse is actually used a very small percentage of the time.
