Re: can bad battery cause ignition problems?
The ignition is self contained and the voltage required by the powerpack is AC voltage that is supplied by the stator (under the flywheel) which supplies approximately 300v AC to the pack. The engine would run without the battery BUT DO NOT attampt to do that.<br /><br />The battery is required of course for the electric starter, other electrical components, and must be in the engine's electrical circuit, otherwise the rectifier will fail which in turn will cause the stator to overheat bad.<br /><br />The stator is a two fold component. One portion charges the battery (small coils), the other portion energizes the powerpack (large black coils).
