Can a tilt soleniod short out
Rush400
The tilt mechanism on my 150 1994 Force is gioing up automaticly. Can the up soleniod short out and cause this?
pnwboat
Re: Can a tilt soleniod short out
It is possible for the contacts in the solenoid to become "fused" together causing this. You should have two solenoids. One for going up, and the other for going down. Both solenoids are identical. Reverse the solenoids. If the problem changes to your motor automatically going down, then the solenoid itself is bad. If no change in symptom, then it's probably your tilt/trim switch. You can try and squirt some WD40 or contact cleaner into the switch. Don't be bashful about how much you squirt in there. Have a rag handy. Might get lucky and cure you problem with a couple of squirts. If that doesn't fix it then you need an OHM meter to check the switch and wiring harness.
john from md
Usually the switch will go bad before the solinoid. Switches tend to get moisture in them and the contacts get bridged or the spring gets corroded and stuck. Easy to check, just put an ohmeter accross the switch.
John
