Hello All,
So I have a 1996 Johnson 115 Bubbleback and the motor ran great with the exception of the difficult cold starts. From all the research I did on this forum (and others), it seems that these motors are known to be somewhat difficult when starting cold. Once warmed up, the motor would start fine the rest of the day (as long as I advanced the throttle, and if I primed it a little if it was off for a while).
But somewhere I read that rebuilding the carbs may help with the difficulty starting issue so I ordered a rebuild kit and decided to have a local shop rebuild them (I mean it couldn't hurt right?) I drop off the boat and rebuild kit at the shop and days later received a call stating that the rebuild was done but that the overheating alarm and light was coming on. Now I NEVER had any issues with overheating and my boat doesn't have any temp gauges, just a buzzer with a warning light. The shop recommends changing the thermostat to start and so I agreed.
After several more days, the shop states that the light wasn't turning on anymore. I pick up the boat and hit the water and the light came on after a short warm up. I turned off the motor for a while and started her up again and the light never came back on. Then all of a sudden mid-day, the motor started running REALLY rough and kept shutting off at idle speed. If I got her started and going, she'd run ok at higher rpms, but as soon as I let off the throttle, she'd die.
I take it right back to the shop and the next day I'm told that the compression is low on one side (like 40 and 60 psi). I'm told that best case scenario it may just be a head gasket, or worst case, the cylinder ends up being scored which would require a whole lot of money spent (either for a powerhead or a re-power).
The question that keeps floating around in my head is why did things go so south all of a sudden? Everything was fine until I took the boat in to rebuild my carbs. Is everything really just bad luck and coincidence? Or could a mistake during the carb rebuild cause overheating issues? I'm no mechanic, but I thought the carb was for fuel/air delivery and the cooling system was different.
Oh, one thing I do wanna mention, within the past year I had the lower unit rebuilt with all new gaskets, new impellor, new VRO pump, new bulb, new fuel filter, new fuel connectors, new plugs, new starter, new ignition coils, and probably more that I can't think of right now. And also, when he showed me the 2 old thermostats, one was closed (which is normal until it heats up) and one was corroded and stuck in the open position. Now wouldn't that mean water is flowing too much instead of restricting it? How would that have caused overheating issues?
Anywho, chime in with thoughts, it'll be much appreciated! =)
