i need to pull my 350 to put in a new oil pump in this week. I dont think the cam i have now is a good fit since it only revs to 4200 rpm and the power band is 2000-6500 or so. Here is the cam i have now
Comp Cams 12-244-4 "Xtreme Marine" Hydraulic Flat Tappet Camshaft & Lifter Kit
Fits 265-400 cu.in. small block Chevrolet V8s
Comp Cams "Xtreme Marine" camshaft is the latest series of hydraulic cams to take advantage of the newest development of camshaft design and valve train technology. It has an aggressive lobe design that produces better throttle response than other cams with the same duration and they still deliver strong engine vacuum. "Xtreme Marine" cams can be used for any high performance application where both low to mid-range torque and good throttle response are desired.
RPM Range: 2,000 to 6,200 rpm
Duration @ .050" lift: 234/244 (int/exh)
Valve lift: .498/.500 (int/exh)
Good for jet boat with A or B impeller, good off shore high performance cam, rough idle.
Comp Cams 12-244-4
? Aggressive lobe design
? Excellent throttle response
? Strong vacuum
? Excellent in high performance applications
? Good low to mid-range torque
So my quetion is, should i keep this cam and prop to a 17 or 19 [ i have a 21 now ]
or shouls i change cams to a stock or little over stock to keep peek power under 5000
Comp Cams 12-244-4
? Strong vacuum
