How does anyone post a picture in the middle of a post like tommays did in the faster planing post. That post is in the mercruiser volvo & omc forum.<br />Did he use a picure hosting site? If so what was the proceedure?------Thanks.
Try tinypic.com and upload your pic. It'll be hosted by that site. There will be instruction on what to copy to insert into a post. Usually its "copy image location".<br /><br />Or, just cut and paste the link after its uploaded url bar at the top. You will need
after te pic in your post here.<br /><br />Good luck!
First..upload picture to hosting site...<br /><br />then open a new window with address to said picture (including name of file)<br /><br />ex. home.comcast.net/~justmrwill/pics/sample.jpg<br /><br />Make sure you see just the picture.<br /><br />Copy the full address from address bar and close that window.<br /><br />Down below you should see under Instant UBB Code(TM) the IMAGE button...***IF YOU ARE REPLYING TO A POST use FULL REPLY BUTTON NOT QUICK REPLY.<br /><br />Click IMAGE an explorer user prompt will open..delete wots there and paste (CTRL-V) the address you copied earlier.<br /><br />
<br /><br />then you should be all set...<br /><br />If you move or delete the file then you get the happy<br />
