natecollins1
- Jun 30, 2006
- 37
I have a 1996 Johnson 200 hp outboard with a no spark condition on all cylinders.
I have changed out the stator, timer base, and power pack with all new CDI components. I have about 165 DVA volts on the charge coil (brown leads) loaded and about 170 volts unloaded. I have about 0.6-0.8 DVA volts on the timer base leads. I have 50 DVA volts on the power coil (orange leads) unloaded and 25 DVA volts loaded. All of this seems good. I disconnect all main wiring harness connections between the boat and engine before attempting to start engine. I have tried to disconnect the shift position switch lead and kill switch lead, but that did not help. I have tried to disconnect the tan temp wire, but that did not help. I have tried to disconnect the black/white temp switch wire, but still no luck.
Can anyone out there help me find other items to look at & test? Thanks for your help in advance.
