Hello everybody,
I have a 2001 Yamaha 150 HPDI that bogs down while at speed or while getting up on plane. It drops down about 300-400 rpms for about a quarter of a second, then goes back to normal operation. It does this sporadically. I recently replaced EVERY filter in the entire engine. I replaced my external water fuel separating filter with a 10 micron Racor filter, changed out the water fuel separating filter in the engine, changed out the VST screen filter on the bottom of the fuel pump, changed out the medium pressure fuel filter, and replaced both micro basket filters inside the high pressure fuel pump. My battery cables are 2 gauge cables that are 18 feet long, so I don't think there is a voltage drop. They are also only 8 months old & my batteries are only 8 months old. The connections are all clean & tight.
Does anyone have any other ideas of things to check for that could be causing this?
Sometimes it takes about 2 or 3 cranks to start the engine, so I was thinking that it could be the lower pressure fuel pump diaphragms. The fuel bulb is hard sometimes and not hard other times.
I put the engine on a new boat this past December, and it ran great all the way up to 5500 rpms. Now on the same boat, it will only hit around 4600 rpms.
I'm not sure if my last 2 comments are related to the problem or not, but I thought I would add them anyway.
Thanks,
Ben
Thanks,
Ben
