Cables for dual shifter throttle and old shifter plate
dlogvine
Master Chief Petty Officer
I bought a 2008 Baja hull without the engine and outdrive. The engine and outdrive I was going to use were newly rebuild 1993 5.0 v8 engine with the rebuilt outdrive. The wiring is matching, I just had to add an extra wire for the gear lube control bottle. But when i tried to attach the shifter and throttle cables i found out that they both h
ave exactly the same connectors and one of them does not fit into an old shifter plate. So my question is, what should I do, change the cable with the old original cable from 1993 boat, change the connector if it is possible or try to find a corresponding shifter plate? Thank you.
p.s. we just got hit by a monsoon thunderstorm with some crazy rain right when I was going to make pictures. So I'll make them tomorrow and attach to the posting
Bt Doctur
shifter plate at the engine end or shift plate in the control box
dlogvine
I was referring to the shift plate at the engine end. And I want to apologize, working in the dark, I completely overlooked that I was using the wrong cable trying to plug it in the shifter plate. The correct cable was sitting under the engine and completely overlooked it. Instead I was looking at the throttle cable which should be hooked up to the throttle level of the carburetor. When I got home and looked at the diagram, right after I posted the question, I realized my mistake.
