Cable Modem
Reel Poor
PLEASE.....Keep in mind I am pretty illiterate when it comes to computers, even some of the terminology.<br /><br />My question is I have cable access and am wondering should I rent the modem from the cable company or should I buy one?<br /><br />If I should buy one what would you recommend?<br /><br />And what are the mininum computer requirements?
mikecjn
Re: Cable Modem
I work for a cable company and we supply our modems for anyone who gets high speed access from us. That is our only option. The benefit is that we also will maintain the equipment at no charge.<br />I don't know who your cable provider is but find out what their policies are.
Cranky18
Re: Cable Modem
Our cable provider allows you to buy a modem. A Motorola SB5100 (similar to what I have) is about $60. I've had mine for about 3 years with no problem.
Boomyal
Re: Cable Modem
I had a D-link modem that worked well for a while. Then I began to get in increased frequency of dropped connections. I called the cable company, they came and check the line and recommended their Motorola modem. It's been a year now and not one problem has occured.
Reel Poor
Re: Cable Modem
Thanks for the responce guys. I like Motorola products. Have always had great reliability from their electronics. <br /><br />I think im gonna try a buy, instead of rent.<br /><br />As for my other question....Is there a mininum cumputer requirement to support the hardware or software??
mikecjn
Re: Cable Modem
Who do you have for a cable company? Do they offer digital phone also? That may help determine which modem to look at also.<br />Motorola makes a good modem but I prefer the Scientific Atlanta modems. I get let service related calls on the SA's.
eurolarva
Re: Cable Modem
I have the motorola provided by Comcast. I am running a Pentium 3 using windows ME and the modem works fine with it. I recommend at least 500 Megs of raam. You dont need that much for the modem but it makes the data processing easier and faster. If you are using a Pentium 2 or older you are not going to experience the true cable experience.
Reel Poor
Re: Cable Modem
mike <br /><br />my provider is cable one. they offer a rental (not sure what brand) for 5. a month.<br /><br />Im just not a renter I would prefer to own.<br /><br />Alittle more info also. My computer is a Dinosaur. Its a Dell 233meg w/windows 98 and a 36k modem. Arrrgggg!!!<br /><br />She may be quite slow, but, im here and postin :D
Twidget
Re: Cable Modem
I bought mine three years ago. It's still going strong. *knock on wood*
NBE
Re: Cable Modem
Given the choice, I recommend buying one. Check with your cable company to see if they ok it and even get a recommendation from them on what type to buy. In my case, my cable company charges ten bucks a month to rent one so it made sense for me to get my own. It paid for itself in a matter of months.
BoatBuoy
Re: Cable Modem
Minimum computer requirements depend on your operating system and other software, not the type of network connection you have.
ZmOz
Re: Cable Modem
Definately buy one. You'll pay for it in less than a year with the savings over not renting. I have an RCA cable modem with Comcast, haven't had a single problem with it in 3 years I've had it, and I almost always get faster speeds than advertised. :D
Reel Poor
Re: Cable Modem
Im definately gonna buy one. Time to start shoppin.<br /><br />Can anyone suggest an inexpensive source.<br /><br />Thanks for all the replys.
KRS
Banned
Re: Cable Modem
Your computer needs to have an internal NIC (network interface card) to plug the cable modem into.
Cranky18
Re: Cable Modem
You can use pricewatch.com to find the lowest price (usually).
BoatBuoy
Re: Cable Modem
Originally posted by azfyrfyter63:<br /> Your computer needs to have an internal NIC (network interface card) to plug the cable modem into.
It does need a network interface. I'm sure a Dell with 233MHz would have a built-in NIC. If unsure, check the back of PC and see if there's a receptacle similar to a phone connection, only a little wider. If it's a little too large for a phone cord, it's a NIC.
NBE
Re: Cable Modem
If you don't have a NIC already there, you can get a USB network adapter that just plugs into the back on the computer in one of the USB ports. Then you connect your network cable to that. That saves you from having to open the box and install a NIC. You still need the appropriate drivers and such installed though. I do still have an old 333 MHz that the kids use hooked up this way and it runs fine. It's also not a bad idea to keep a dial-up connection as a backup. There are several reasonably priced (ten bucks or less a month) and fairly fast services available out there. Just depends on how bad you need to stay connected. In my case, I do work from home from time to time and connect to my work network from the house.
