Cable filters and if anyone has used one before?
muskyone
Master Chief Petty Officer
Re: Cable filters and if anyone has used one before?
what do you mean by cable filter do you mean for cable tv
dr_bowtie
Cable TV filters....
And yes I have...there are different filters for different needs... most filter out interference...like backfeed into the line that messes with neighbors...they use filters to keep the Internet signal clean...some filters block Internet so if you dont have it you cant get it without the right filter...
make sure all your connections are tight and interference wont be much of an issue..these need to be more than finger tight...even if you dont see it on your TV it can be in the line...
Father-inLaw works for the cable company...:)
muskyone
there are filters and then there are traps. the only filter i know of is a hp50 which filters any outgoing signal from your house back into the system. if you have Internet this should be on a splitter if you don't there in the ped or on the pole.
a trap stops a channel or a block of channels from coming in there are + and - ones positive you put in to get the channel neg you take out. so again whats your ?
my experience I'm the guy they call in when they cant fix it
coax splicer
sweep tech
fiber splicer
head end tech
and we still do construction so a aerial lineman to
bruceb58
This just looked so fishy!!!
Looks like the screen name at the beggining of this thread and the one at the end are related!
http://74.125.155.132/search?q=cach...echstep+cable+filter&cd=1&hl=en&ct=clnk&gl=us
do a search for "Cable filters and if anyone has used one before?" This guy is a busy guy!
Adjuster
LOL that was almost clever.
slia67
Good catch, bruceb58!
bruceb58
The second offending post has been removed here but if you do the google search you can see it on other sites.
