Bypass cover leaking
Newfie1981
I have a 1980 85 Johnson sea horse it idles rough and shuts off if not on high idle I have notice that one of the bypass covers are leaking oil I checked the 4 spark plugs and have notice that one plug got like carbon deposit on it and that same cylinder is we're the bypass cover is leaking would this be the cause for the carbon deposit and the rough idling thanks
Honorary Supreme Mariner
Not likely.----I am going to suggest you do a compression test on that motor.----Post your results and we go from there.
emdsapmgr
A leak in the bypass cover gasket will leak crankcase compression. (not the same as piston cylinder compression) You'll lose a little performance from the leak. Could cause that cyl to suck air, possibly resulting in a slight lean condition. Pull the cover off and replace the cheap gasket around the cover. 307133. About $3.
Newfie1981
Ok done a compression test 125 psi on all four cylinders going to order a new gasket it starts fine but when idling it's like it's sneezing hope it's not to serious also is there supposed to be any water coming out the exhaust thanks
oldboat1
When you pull off the bypass and replace the gasket, I would clean under there with carb spray to clean it up. Are you getting overheating issues?
flyingscott
Sounds like you have a lean sneeze at an idle. Does it go away after it warms up
Newfie1981
It's not so bad when it warms up notice I had a little fuel leak repaired that and seems to run a lot better it doesn't shut off now but still has a little miss
oldboat1
Check the temps up at the top of the heads. Think you have a couple of t.stats down at the bottom. Idle temps at the heads should be 140F or so, but can vary some. Cold running can give idle problems and fouling. Shut it down if it goes above 160.
Newfie1981
Now that you said that, bank number 1 is hotter than bank number 2 and bank number 2 is we're the fouling is happening I will replace the two t.stats and see what happens thanks everyone for all the great info much appreciated awesome site
