Took the boat out today after an hour or so the buzzer went off and the engine started to bog down. I shut it off quickly and checked the temp. It was fine (good water flow) cranked her up and the buzzer was still going. When I went over 3000 RPMs it started to bog down. (idle was fine) Then my buddy noticed that the prime bulb had collapsed. He played with the prime bulb and got the buzzer to go off and the RPMs to pick up to normal. This happened three times but on the last time we got the buzzer to go off but it was still bogging down if tried to go over 3000 RPMs (coasted home below 3000 RPM). Could this be a fuel or electrical problem? Sounds to me like not enough fuel, could the pump be going bad and causing this?<br /><br />Evinrude 1991 200hp<br /><br />Thanks
Al
