Buying Volvo Question
kstuart
Do volvo's drives have a water impeller in the drive to get the water up to the water pump? I'm looking at getting a 97 larson with a 3.0 volvo, what things should i check out on the engine to make sure its good, i've only owned mercruisers so i'm not sure what to look at thats special to volvo.
Gary H NC
Re: Buying Volvo Question
Many Volvo setups use the engine mounted impeller pump.(belt driven)
You need to post the model and or serial numbers of the engine and drive.
Welcome to Iboats!
bruceb58
All Volvo sea water pumps are on the front of the engine. Yours will be driven by a belt.
