Re: buying a new prop
Not unless is specifically says so. My experience is when you buy a prop, you just get a prop. If it is a hub system prop, then you will only get the prop housing, and the hub is extra, unless it specifically lists two part numbers - the prop housing and the hub. When in doubt, call them!<br /><br />Mark
